86 hood latch release
Old 01-20-2011, 06:23 PM
bankruptbrincko
5th Gear
bankruptbrincko's Avatar
Default 86 hood latch release
I went to pop the hood and the release handle broke off. How do I get under the hood now and how do I go about replacing the handle?
Old 01-20-2011, 06:50 PM
oldalaskaman
oldalaskaman's Avatar
if only the plastic is broke , you may be able to use a pair of chanell lock pliars to 'lever' it. you can also unbolt it and pull it. it only gets worse from there.
Old 01-20-2011, 06:51 PM
Bob86ZZ4
Bob86ZZ4's Avatar
Yep, hopefully you can grab each cable and pull with a good pliers to get the hood open. You can get a replacement handle from one of the parts restoration places, Mid America, Corvette Central, etc....
Old 01-20-2011, 06:56 PM
raiderz
raiderz's Avatar
When you do get it open---install a set of emergency cables for the next time. Simple install and easy to use.
see link http://www3.sympatico.ca/tlavier/hoo...tructions.html
Old 01-21-2011, 09:20 AM
70ZZ3 96LT4
70ZZ3 96LT4's Avatar
Default picture
Do you have a picture of your installation of the backup hood release?
Old 01-21-2011, 09:26 AM
oldalaskaman
I bought a complete kit , including upgraded springs, new in the box , from corvette recycling for $49 bucks. The stock springs are, in my opinion, the reason for so many problems with these hood release issues. After installing the new ,upgraded springs , and using them for a few months, I got rid of the "emergency" release cables that I made. They are just that reliable.
Old 01-21-2011, 09:57 AM
70ZZ3 96LT4
Default hood release
There is a tool that can be purchased to come in from a opened door on each side of the car to connect to the hood latch to release them.
Old 01-21-2011, 10:20 AM
raiderz
raiderz's Avatar
Default Install Instruction and Pics
Old 01-21-2011, 10:31 AM
pmihaltian
Slingshot
Support Corvetteforum!
pmihaltian's Avatar
You can get this special Hood Release Tool at most Corvette parts houses for about $20. OR, you can make your own. Also, attached is a write-up on how to use the tool.
Good luck
Old 01-24-2011, 01:35 AM
bankruptbrincko
5th Gear
Do you know if this kit comes with installation instructions?
Old 01-24-2011, 01:40 AM
oldalaskaman
yes it did , and I seem like I'm selling them , but I'm not, after fighting , adjusting ,greasing , and just generaly being agravated by the stock parts, this was the best thing I've bought. you wont be sorry
Old 01-26-2011, 08:40 PM
bankruptbrincko
5th Gear
It turns out that the release handle was not broken at all. The pin/shaft that goes through the release assembly that the handle itself rotates around had worked its way out after years of use. All I had to do was remove the housing and reassemble everything. As far as initially getting the hood open again, all it took was a yank on the cables...no pliers needed. Thanks to all for the great information.
To 86 hood latch release
Quick Reply: 86 hood latch release
