Just got Bosch Design III Injectors from FIC
Can't wait until it warms up so I can these installed in my 87... I got the Bosch design III flow matched, 22lb set. I have a couple of leaky injectors so I am confident these will fix the problem.
Any tips or tricks when changing injectors would be appreciated. Been working on cars for over 20 years but have yet to change any injectors.
Thanks for any help
Thanks for any help
Hi 87redvet, I am in the middle of this job right now after getting some bosch 3's from Jon, mine is taking a little while as i am doing a port and outside polish on the plenum and runners and fitting an adjustable fuel pressure regulator,
the best advise would be to read the fuel injection sticky at the top of tech-performance by FIC, there is a video by calderone showing the job being done, I used this info to do mine.
Second big tip, dont let the O ring on the back of the fuel runner fall out if you have a cold start injector, its a bit scary when fuel sprays into the side of the distributor at 39psi !
1 Post
Thanks for any help
Thanks for any help
Been there, done that. Easy job but time consuming. Plenty of tech tips on this. I did the one where you don't have to remove the runners. They can be a real pain, so why cause yourself more time and trouble. Others may differ, but I've gone almost 2 and a half years with no issues. Jon at FIC will help if u have questions.
St. Jude Donor '05
Did this job last year on my 87. I found it best to remove the passenger side runner and mess with the driver's side as little as possible. The cold start connection to the fuel rail is a real PITA to get aligned, and some of the wrench sizes needed came from way in the back of the drawer. Be careful working around the EGR temp switch; if you break that wire it's another PITA, and you cannot buy a new one. Don't believe Calderone's 2 hour claim unless you have removed the AIR setup already (but this is a good time to do it). ....and keep Jon's number; he is always ready to help as much as he can. Good Luck.
I pulled the plenum and left the runners attached also. I just unbolted the TB and let it float too. Unbolt and split the fuel rails (little torx heads keep them from sliding apart) and your ready to remove the clips from the old injectors and put the new ones on. Why wait? Easier job than I thought it would be and it went pretty quick too. Fixed my issues.
The nice thing about not using clips on the injectors when you install say Bosch III. Is if you need to pull them later, then I think it is supposed to be easier. As I believe you can just lift the rail up some and pop the injectors out vs. having to remove the rail to undo the clips to get the injectors out of the rail.
I have a set of the Bocsh Design III injectors sitting on the shelf after I installed them I found they ran very nice with more power. I was very happy with Jon and his help with questions I had. When I took it in for smog testing, it failed. The report indicated a rich condition. So, I hooked my laptop up to the ALDL to find the BLM was pegged at 160. It could not lean the engine down any more. I had to remove them and replace with my original injectors after having them cleaned and tested. After this the Corvette passed easily. When the BLM is showing a value of 160 the ECM can't make any more adjustments, so, you wind up with a very fancy carb. In my experience 22 lb injectors are too much for a stock L98.
Gary
Gary
Gary
Gary
I installed 24 lb Trickflow injectors in my 88 and it has passed 2 California smog tests. I have to get it smogged every 2 years. It's my DD. It runs smooth as glass and gets good mileage. I couldn't be happier with the way it runs. Everyone on this forum told me I was making a mistake by not installing Bosch 3s.
22lb injectors should be the stock replacement.
I installed a new Bosch 3 set from FIC, and I added an adjustable FPR.
With the engine running and a look on the integrator I adjusted the fuel pressure for a 128 value on idle.
Then I rechecked the other cells for BLM after a couple days driving. You need to let the computer learn the new injectors behavior....the values were 128 +/- 4, 5,6 so this is ok I think.
Don´t forget to unhook the battery while doing the injectors to clear memory. Otherwise it won´t run right.
Some have had good luck with the newer Accels. The old style Accels were complete crap but the newer ones appear to be much better. Here is a comparison. They are cheaper than the Trickflows.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Of significant note is the actual installation of the injectors.
Make sure the intake manifold bores are clean!
Wipe 'em with a rag using alcohol.
Then lube the bore & o-rings lightly with silicone grease before inserting.
