No Hatch Ajar light
Old 02-03-2011, 11:30 PM
41canine
Cruising
41canine's Avatar
Default No Hatch Ajar light
After searching the forum I've got to ask for help.
'96 Cpe and the "Hatch Ajar" light does not show in the dash. All of the courtesy lights work and the "door ajar" indicator works for both doors. I pulled the hatch ajar switch and there was no power to the switch. All the fuses are good unless I missed one. Any ideas would really be appreciated.
Thanks everyone.
Old 02-04-2011, 10:59 AM
pcolt94
pcolt94's Avatar
Default Quick reply
No time right now, but when I get a chance I will check the FSM and see if I could get a definite answer.
However it is possible the switch might be a ground return from the CCM and have minimal voltage on it. Also check the bulb in the DIP panel and see if it is burned out.
Old 02-04-2011, 12:25 PM
41canine
Cruising
41canine's Avatar
I checked the wires going to the switch and there was no power. One side of the harness going to the switch goes to a ground. Clean and tight. If it's the bulb in the DIP panel, I may just ignore it. Does it show there, or in the speedo area like the "door ajar" lights? I'd appreciate you checking the FSM for me. That would be great.
Old 02-04-2011, 12:33 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
If you look in the mirror and see the hatch open, it's ajar. Just being funny. Good luck.
Old 02-04-2011, 07:29 PM
41canine
Cruising
41canine's Avatar
Never thought of that. So, if all of a sudden the little dog is gone, it's probably the same indicator......Thank you
Old 02-04-2011, 08:57 PM
pcolt94
pcolt94's Avatar
Not sure how much I can help on your 96, I have a 94. We might need to re-group, not sure. Don’t know if your car is different than mine in that area or not. I to have a door ajar on my Speedo but I do not have a hatch agar light anywhere (speedo or DIP).
However when the hatch is open, the security light on the Speedo flashes. I did check the FSM and the agar switch which is normally open, goes to ground, and the other terminal goes to a CCM input terminal. The security light is part of the thief system and is driven by different inputs to the CCM and the logic in the CCM firmware.
So it looks like my "hatch indicator" is the security light. Is it possible that you never had a "hatch ajar light? If you did definitly have one, it must me a 96 item.
Old 02-05-2011, 01:48 PM
41canine
Cruising
41canine's Avatar
Thank you pcolt. You are absolutely right. You nailed it for me.
That's exactly what is happening. Thanks for saving me from a lot of work and insanity. I really appreciate the help.
Old 02-05-2011, 05:38 PM
markKlein
markKlein's Avatar
I think the interior lights should also come on when the hatch opens.
Old 02-05-2011, 06:45 PM
RedLS1GTO
RedLS1GTO's Avatar
Originally Posted by PLRX
I think socalman, Red and Ch@0s had that problem and they bought the light in pep boys. Corvette Mike bought an aftermarket sensor for it.
I eventually got mad enough that I just said screw it and ripped the whole interior out.
Old 02-05-2011, 08:04 PM
socalman
socalman's Avatar
St. Jude Donor '10
I'm still trying to find my hatch
Old 02-05-2011, 09:58 PM
ch@0s
ch@0s's Avatar
They had the wrong light in stock. I'm still waiting for the right one. When it gets here I will post the part number.
Old 02-05-2011, 10:07 PM
Bronze85
Bronze85's Avatar
When is a hatch not a hatch?
Old 02-05-2011, 10:44 PM
RedLS1GTO
RedLS1GTO's Avatar
Old 02-07-2011, 05:14 PM
41canine
Cruising
41canine's Avatar
They do. Thank you,
Old 02-07-2011, 05:15 PM
41canine
Cruising
41canine's Avatar
Outrageous!!
To No Hatch Ajar light
Quick Reply: No Hatch Ajar light
