Camaro Flywheel and Sprung Clutch Disk Review
Guys I thought I would post up my review of the camaro clutch disk and flywheel.
The whole reason for switching to a single mass flywheel came about when I noticed that my dual mass flywheel had leaked a grease like fluid all over the inside of my bellhousing. It could be seen through the inspection cover. At first I thought it was rear main seal leak but after transmission removal it became clear that it was coming from the flywheel.
I had 96 camaro flywheel from a previous car of mine so I didn't have to find one at a junkyard. I took it to a driveline shop and had it resurfaced .090. This is alot of meat so it was not cheap to do this $80. I then took the camaro flywheel and corvette pressure plate (with bolts) to an engine shop to zero balance it for my Golen 383. This costed $75.
I then bought a valeo 93-97 camaro stock sprung hub clutch disk. This can be purchased on ebay for $100.
You will also need some different flywheel bolts. These are the same flywheel bolts that go on a 93-97 camaro. I bought ARP but you can get these from the local auto parts store.
I reused my corvette pressure plate because it had not been on the car for very long and it still had the original valeo grooves on the clutch surface.
I had read alot of stories on corvette forum about a noise called "box of rocks" coming from the ZF6. Well I'm here to tell you that my black tag Zf6 is extremely quiet in all gears. There is a very faint "box of rocks" sound only when I have the clutch pedal out and transmission in neutral(almost never happens). If the heater or ac is running you cannot hear it at all. If the radio is on you can not hear it at all. I am completely satisfied with the clutch.
It engages very smoothly and holds the power of my 400hp 383 without a problem. I think that the fact that it is a sprung hub disk is the key here. A solid clutch disk likely would cause the noise problem to be a real problem.
For guys looking for an inexpensive driveable quiet clutch with a single mass flywheel this is the ticket.
Oh by the way, the single mass flywheel and corvette pressure plate were so well zero balanced that I can now rev up 6500 rpms without the car vibrating at all. Its like driving a lexus its so smooth.
It's nice to hear you don't have any major issue with noise. I know ZFDoc's website says there can be variance from one ZF to another -- which results in more/less idle noise. I also think the newer blue tag (like you have) is quieter than the older black tag models.
At any rate, it's great you're happy! Many happy miles to you!
Pro Mechanic
I've always wondered about this solution...and why not? More so, I've wondered why this hasn't been tried sooner, or more?
The DMF moves the "sprung hub" into the FW. I don't know why that was necessary in the first place. It seams like an expensive, heavy, complex solution. Why NOT use a sprung HUB clutch to absorb the power pulses like most every other car uses? I think that it's a great solution and an economical one to boot...especially after the first install.
Props to the OP for pursuing this and posting the results. Thank you.
good post......I would have to imagine however the FW from the 96 Camaro was steel.....making the "rocks" sound even more muffled from the ZF.....the problem is mainly with aluminum single mass FW's like many guys are running.....like myself......I am running a spring hub disc as well, but even with that and the blue tag, I get the rocks noise and it is prevelent under 900 rpms at idle w/o the clutch engaged....
I do have a new, steel, single mass FW in my basement for a reserve unit though that will be quieter (like the 96 Camaro unit you referenced).....
1 Post
[QUOTE=93VettePilot;1576765502]Guys I though I would post up my review of the camaro clutch disk and flywheel.
Was the resurfacing required to make it the same thickness as the dual mass?
I have a SPEC steel flywheel and a sprung hub. Rattles like a box of rocks. FWIW, this is in my 383 that is ~500hp at the crank
The key is idle speed. If I set my idle speed to ~950pm to get rid of the cam lope, it's not too bad. At 800rpm it rattles. My cam is .622/.624 lift with 230/236 duration.
Pro Mechanic
Received 3,043 Likes
St. Jude Donor '05
LT1 Pressure plate bolts discontinued from GM last yr. Lots of places have a listing but wont have them in stock.
Thanks for all the replies. Hope this helps someone out.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I am giving serious thought to doing this now, why did you need different flywheel bolts? How are they different than the Vette bolts?
