Optima Gel Cell Batteries
My reason for wanting one is because I have a friend that can get them really cheap Reason for needing one is because my car has been in storage for over a year, and I'm pretty sure that my brand new (at the time) Diehard won't be able to return from the dead
Wow, that's interesting
Also note in the other thread where modifications need to be done to one, in order to make it fit your '96.
Gottcha, I thought that they probably weren't a direct fit Sucks that the quality of the batteries apparently isn't there anymore.
There is not made much in the USA anymore. Any car or truck replacement parts.
The original OPTIMA batteries were made in the USA.
They are now made in Mexico.
Better than China i figured at the time of purchase.
I needed a battery for my 87 Vert last fall.
Another AC delco failed. had enough of them.
Installed a Red Top Optima. Group 75 sidepost and top post.
Car starts right now every time. The old Delco 10MT spins the engine over effortlessy upon startup.
You cant let an Optima discharge slowly over time from non-use, extended periods of time. They dont like that at all.
The ECM draws slightly always with the battery connected and car - ignition off. Around 15- 50 Milli amps.
Will draw any battery down over a month or 2. Dead battery.
Disconnect the negative battery cable if the car will sit more than 2 weeks unused.
Or purchase a trickle battery charger of some sort.
ALWAYS use a battery tender if your car is going to sit for long periods. Batteries kept charged will have a normal life, batteries not charged will be a door stop.
Go and sin no more!
I went through 2 Optima batteries until I had enough and got my money back. Mine would discharge enough not to start my car within 5 to 7 days of sitting. There were no shorts or other issues with the car, and now that I have gone back to a regular battery, no more dead battery after a week of sitting. My local Vette garage has discontinued selling them for replacement in the Vette's they work on for the same reason. I couldn't believe that a battery (especially at the price of the Optima's!) would turn out to be such crap!
There is no real advantage to to an Optima in your Vette. They are mostly for remote or other odd positioning and high vibration applications. Unless your buddy can get one for less than a regular battery, save your money for something else.
Optimas also take special care for recharging. http://www.optimabatteries.com/produ...agmbattery.php
That is there main advantage.
You can put a .357 Magnum bullet through it.
Wont leak acid.
Thought about a BRAILLE Battery but they dont have much reserve capacity compared to an OPTIMA Red or Yellow top when checking specs against each.
The Carbon Fiber cased LITHIUM BRAILLE Battery is pretty cool.
Was used in the C5R and still used C6 Racing and Indy Car Racing series.
But at Just over $2,000.00 LOL
Braille makes the ultimate batteries. Little much for the average driver on the street.
I have known people to use the same Red Top Or Yellow Top Optima battery for 10 - 15 years. Still working.
But they took care of them too. Never let them discharge slowly and go flat dead.
Have to keep an Optima Charged to at least 12.4 - 12.6vdc at all times.
12.6vdc being ideal.
Or they wont last you too long in years of ownership.
Or just Buy an ordinary lead acid battery.
Have it leak acid all over one day in your Vettes engine compartment catching you buy suprise.
Optimas are not for any car owners that do not maintain their car and have no mechanical or electrical troubleshooting and repair skills of their own.
Got my Optima Red Top Battery at my local NAPA store for under $90.00 my cost(Veteran Mechanic's Cost) out the door with tax.
Free 2 year replacement warranty.
No questions asked.
No Prorated BS like most batteries.
So I said why not and bought one.
Works great. And I know better than let it go dead that Red Top Optima.
BR
I've NEVER experienced a leaking battery.
Not saying it doesn't happen. But that condition is blown way out of proportion.
Look how many millions of cars/trucks get normal batteries.
The percentage of those that leak during the batteries normal life span is so small, you would have a hard time measuring it.
