Fuel Pressure Regulator Replacement
What is the procedure for removing the Fuel Pressure Regulator on a 1990 Corvette?
I have not done a specific FPR replacement, but I have pulled the fuel rail to swap injectors and I have installed an adjustable FPR before.
With that said, I would think you will need to pull the plenum, but not the runners to get to the FPR to replace it. You will need to loosen at least one runner to get the plenum to come free.
You will want an intake gasket set(including throttle body gasket), some teflon tape (to wrap the brake booster vacuum line threads), a long T-40 Torx ratchet bit (Snap-on makes one, but I couldn't find one at Sears), along with the regular tools.
if you have not disassembled an L98 intake before, you can check out my intake swap photo doc here:
http://members.***.net/effergyvette/...e_install.html
I am relacing my injectors which has turned into a lot of might as well do this project . I have spent the last 3 evenings polishing jut one runner but man it looks good .so its a while before I put the new injectors in . Should I relace the diaphram on the fuel pressure regulator ? Its not broke (so why fix it ?) but car has about 90,000 mikes and I did ruin the injectors with lucas oil so maybe the diaphram is next ? looks like most auto parts stores have them for around $40 so what do you guys think ?
Here is the link to the rock auto one.
http://www.rockauto.com/catalog/rafr...-217380-311796
Your link to this experience is broken or it has timed out could you resend it to my email address rkevinsdad@yahoo.com so i can start on my 86
If you can, I'd return them and get reman ones. Much cheaper.
How did you ruin the injectors with lucas oil? Surely you didn't try put it in the fuel rail??
You'll have to get a C4 parts manual to look up the screw size. You can find it in a PDF format. But get new allen head screws before hand. I had problems of the screw heads on OEM screws stripping out.
This link is broke
