ZF black and blue tags
Old 03-03-2011, 09:42 PM
QCVette
QCVette's Avatar
Default ZF black and blue tags
I had my 94 on the lift last weekend and now I am curious.
The transmission has the normal black tag. Below the black tag is another smaller tag that says it was remanufactured. Below that tag is a blue ZF tag the same size as the black one. I forgot to take pictures and I am finished with the exhaust so it is down again and I can't take pictures for a while
I am not sure what all the tags mean. My guess is that it was a black tag transmission that was rebuilt by ZF. I am not sure if the blue tag means it was rebuilt with the blue tag internals or not.
Anyone have any ideas?
Old 03-03-2011, 10:21 PM
87 vette 81 big girl
87 vette 81 big girl's Avatar
I used to buy quite a few parts from Jason @ vette2vette in Streator, IL.
In his late 30's.
I often would look at all the Corvettes he had apart.
1984-1996 & 1997-2004.
It was AMAZING THE AMOUNT OF PARTS ON HAND.
Even more amazing was his vast knowledge of C4's and C5's.
Sort of like the Gordan Kilebrew of his generation.
They are actually good friends.
But Black Tag ZF's I understand from talking to Jason were for 1990-1995 ZR-1 cars.
The Blue Tag ZF's were for 1989-1996 Non ZR-1 DOHC powered cars.
I may be mistaken.
What ever trans they used in the ZR-1 cars were definite Heavy Duty Items.
Never heard of one failing in "Z" car unless it ran out of gear oil.
Brian
Old 03-03-2011, 10:29 PM
By the way, I am unsure why your ZF 6-speed has both the Black Tag and Blue Tags intact on it.
I recall the tags being production date coded.
That may help you figuring out what you really have.
ZR-1 Spec trans would nice to have.
Brian
Old 03-04-2011, 03:08 AM
rodj
rodj's Avatar
Originally Posted by 87 vette 81 big girl
Black Tag ZF's were for 1990-1995 ZR-1 cars.
The black tag was from '89 to mid '93,
the blue tag was from mid '93 - '96.
Black tag units were made in West Germany, by ZF. By 1993, GM was making them under license in the USA.
There were a number of complaints about gear whine on the black tag units.
So the blue tags were "quieted down" by cutting the gears at a steeper angle than those in the black tag box.
The result is marginally weaker box
450 ft/lb rating for the black tag, vs. 400 ft/lb for a quieter but not quite as strong blue tag.
ZR1 had the same identical ZF6 trans; year for year
Only changes were input shaft length was different and a different bellhousing to suit the LT5
vettespecial (04-13-2019)
Old 03-04-2011, 03:18 AM
Thanks for the clarification On Black ZF and Blue tag ZF's.
I will remember your lesson too.
Brian
Old 03-04-2011, 06:45 AM
LD85
LD85's Avatar
www.zfdoc.com
Old 03-04-2011, 09:32 AM
cv67
cv67's Avatar
Received 3,043 Likes on 2,602 Posts
St. Jude Donor '05
Could have been a dealer replacement when the car was under warranty?
THey dont always put new parts in, they have th right to put used/rebuilts if you read the fine print, at least with late models its that way not sure about the 90s.
Old 09-05-2013, 04:04 PM
BOSTONCAMARO
BOSTONCAMARO's Avatar
hi so if you have a black tag out of a ZR1 and a black tag out of a non ZR1 sitting next to each other on the ground, the only way to identify at first glance as that the ZR1 will have a shorter input shaft?
Old 09-05-2013, 05:34 PM
WVZR-1
WVZR-1's Avatar
Received 2,259 Likes on 2,022 Posts
The LT5 would have the increased length! Internals are by the actual part # of the transmission and the "black tag" 610 Nm share the same and the "blue" 540 NM share the same internals.
There are only 2 input shafts, L98/LT1'LT4 share and the LT5 is by itself. The S6-40 was also used in the Lotus Carlton.
Old 09-06-2013, 12:08 AM
89onlyZ51
89onlyZ51's Avatar
Can you read the tags? The second (blue) tag is probably the fluid recommendation tag.
Old 09-08-2013, 06:09 PM
TorchTarga94
TorchTarga94's Avatar
Some 94's also got left over black tags. Mine is one of them.
Old 09-08-2013, 06:11 PM
TorchTarga94
rodj is spot on. A few 94's also got left over black tags units. Mine is one of them, I know there are a few other 94's on this forum with factory installed black tags as well.
Old 09-12-2013, 03:34 PM
BOSTONCAMARO
anyone have a measurement of the input shaft from say the face of the trans case to the end of the shaft where it slides into the pilot bearing? I am sure the NON ZR1 models are more common and I have seen some popping up at swap meets...my car is set up for a NON ZR1 6 speed, so if I trip across one, want to make sure I am getting the right one as a spare
thanks
Old 09-12-2013, 04:06 PM
WVZR-1
WVZR-1's Avatar
thanks
159.5mm for the L98/LT1 & 4 (6.27953 in)
190.5mm for the LT5 (7.5 in)
That's case to the tip of the input-shaft
Old 09-19-2013, 10:28 PM
BOSTONCAMARO
Thanks!
Old 04-05-2019, 05:16 AM
juni78
juni78's Avatar
Hi, do you know the reason? I have same tag on my transmission and I am courious...
To ZF black and blue tags
Quick Reply: ZF black and blue tags
