Evaporator Purge Canister
7th Gear
Can someone help me locate the Evaporator Purge Cannister on a 96 LT1 ? (Getting a code) Also any advice? Replace the solenoid? Gas Cap? Thank you all in advance!
The correct procedure to repair the code is to follow the step by step diagnostic tree in the Factory Service Manual. That said, you may want to ohm test the solenoid as they are a common failure item. With the connector removed take a reading across the two pins, no need to note the reading, a bad one will be "open" (infinite resistance). Hope that helps.
