How easy to change front pump of 700r4/4l60?
Old 04-27-2012, 01:49 AM
Cliff Harris
Cliff Harris's Avatar
You can buy a pump from these guys for $225:
http://www.bowtieoverdrives.com/cata...php?ITEMID=346
You need a pump with the auxiliary valve body pipe (1987-1/2 and newer).
You'll need new stator shaft ring seals also.
Old 04-27-2012, 11:30 AM
mfi
mfi's Avatar
Well since this is where the tranny experts are..have a question.
My 92 tranny lost reverse after only 7000 miles, in 7 years but still 7000 miles..they said the piston cracked. How can that happen, not that I know what piston they are talking about, but even they could not explain how it happened...
Old 04-27-2012, 01:45 PM
btr85vette
btr85vette's Avatar
I don't want to hijack the thread, but I have to do this to my 85. Arrrrrrgh...
Would it be worth going with the 87 pump vs. using the stocker 85?
Old 04-27-2012, 10:52 PM
pricesgarage
pricesgarage's Avatar
if u go to a 87 up pump plug the reverse feed hole and yes the 10 vane is a better pump but u can upgrade yours with a new rotor slide vanes even to 13v
Old 04-26-2016, 10:41 PM
Mherndon
1st Gear
Mherndon's Avatar
I recently ordered an aftermarket oem factory pump front Monster Transmissions if anyone is looking for one. Great company.
Quick Reply: How easy to change front pump of 700r4/4l60?
