When I worked on lowering mine I didn't use a kit. Cut the stock rubber down to about 1/4". No need to mess with gluing new wedges on. Also cut down the rubber on the ends of the spring. Mine lowered down 1" with that.
What's the easiest way to trim the spring end pads down? I used a hack saw to cut the middle pads down but that doesn't look like it would work for the ends.
