C4 1993 Brake Rotors recommendations?
And CHANGE your brake fluid. Its probably old and nasty.
Street I like the HPS's on the wife's car. I've used the Carbotech AutoX pads and liked them.
Received 1,754 Likes
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
Check out KNSbrakes.com They are a forum vendor here and are very helpful on applications like this.
mpodell (07-20-2022)
Supporting Vendor
St. Jude Donor '11,'13
The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser, and has won multiple SCCA Solo 2 and Prosolo National Championships. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. Bobcat 1521™ compound has also been found to extend the life of your rotors 2-3 times. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
actually reminds me a lot of the PBR/axxis ultimate
also agree with the sponsor on the 1521 for most street apps. it's a better pad than the HPS especially in regards to pad life. the ax6, hp+ and ultimates would be where you would look for a street/autocross pad and or an aggressive driver with 300+whp and stickier tires {nitto nt05 or better}
