1993 Rough Idle cold start clears up quickly??
Old 03-28-2011, 06:37 PM
BIGJIM13
BIGJIM13's Avatar
Default 1993 Rough Idle cold start clears up quickly??
Guys
last few day my 93 starts right up on cold start up but tries to die and idle
drops off and it bucks and kicks for about two minutes and I get it moving and after about 1/2 mile its just fine no problems - anyone have any quick fixes or what to look for?
Old 03-28-2011, 09:53 PM
rob-cyn
rob-cyn's Avatar
My 94 was doing this. Until it will now not start at all, it is getting fuel as I can smell it but probably not getting any spark. It has poured down here all day today so I have not had a chance to check it out.
Old 03-29-2011, 11:35 AM
78pacer
78pacer's Avatar
I would suspect an O2 sensor. There are heaters in the sensors that go bad and make the vehicle run rich. Before you toss $$ at it, scan the system upon a cold start and see what is found.
Mike
Old 03-29-2011, 06:24 PM
BIGJIM13
BIGJIM13's Avatar
the only code I get is a 16 - low pulse - opti is 3 months old
Old 03-29-2011, 09:45 PM
bwiencek
bwiencek's Avatar
If you smell a bunch of fuel at startup then I'd say leaking injectors - they dump fuel into the engine while it's off, then when you start those cylinders are flooded so it runs rough and once they're clear then everything runs fine.
That or a weak coil/opti.
Old 03-30-2011, 09:50 AM
-=Tom=-
-=Tom=-'s Avatar
Mike
I don't think it's the O2 sensors as they're not in the loop until the car warms up. His issues are at startup while the car is cold.
Old 03-30-2011, 09:02 PM
rob-cyn
rob-cyn's Avatar
Was a bad ICM on mine. Thats 2 in 6 months.
Old 03-30-2011, 10:30 PM
94vettelover2
94vettelover2's Avatar
Could be a leaky fuel pressure regulator but your code is indictating a opti problem or wiring issue.Also check fuel pressure & coolant temp sensor.Keep us posted
Old 10-05-2016, 05:23 PM
Mykster
4th Gear
Mykster's Avatar
Default 94 Base Start Up
Mike
Hi everyone,
My 94 Base coupe with 56K just started running a little rough when cold and what sounds like an unhappy lifter. The noise seems to be coming from the drivers side of the motor. It clears up and runs strong after driving for 3 or 4 blocks. What do you mean by scanning the system? Sorry, it is my first 'Vette.
Old 10-06-2016, 09:04 AM
JimLentz
Support Corvetteforum!
JimLentz's Avatar
Originally Posted by Mykster
Hi everyone,
You should probably start a new thread so people will see your question. Here is a good article on scanning the codes.
Old 10-06-2016, 10:06 AM
aklim
aklim's Avatar
Received 2,218 Likes on 1,932 Posts
Mike
How so? The O2 sensor isn't active till it heats up and he is dealing with a cold start issue.
Old 10-06-2016, 10:56 AM
BLUDICE
BLUDICE's Avatar
Mine did this a couple weeks ago - was the temp sensor on the water pump - I pulled the plug-in and re-attach and it clear up - I guess it had some corrosion in it.
Old 10-06-2016, 11:49 AM
aklim
aklim's Avatar
Get a scanner and see if the start up temp is the same as an infra red scan of the CTS.
Old 10-06-2016, 12:20 PM
antfarmer2
antfarmer2's Avatar
Old 10-07-2016, 08:28 PM
BLUDICE
BLUDICE's Avatar
So BIGJIM13 how's you car now??
Old 08-31-2020, 09:48 PM
Brian Meadowcroft
1st Gear
Brian Meadowcroft's Avatar
I had to create an account to say thank you. I pulled the water pump temp sensor, cleaned it and re-attached and IT WORKED!
To 1993 Rough Idle cold start clears up quickly??
Quick Reply: 1993 Rough Idle cold start clears up quickly??
