J55 Brake Kit pad fittment - Racers?
Racers or autocrossers, we need a little help here.
For those of you using the J55 front brake kit, what Hawk Blue part number pad are you using?
If using some other aggressive bite pad, what is it (brand and p/n) , and perhaps I can cross-reference.
Thank you,
Ed LoPresti
Thank you,
Ed LoPresti
Carbotech XP10 up front, XP8 in the rear. I've used both. I like the feel and performance of the Carbotechs better.
Thank you.
Thank you, Gentlemen, for the input so far. At this point, I am looking particularly for fittment information for the J55 caliper/rotor combo, and not so much compound designations.
It appears so far that the later C4 "stock" calipers, and the J55s, can use the exact same pad. I am puzzling on why that is so, since the rotors are different diameters. Is it just that on the 13" rotor, tha pad contacts less of the swept surface?
For those of you using the Performance Friction, or the Carbotech pads, if you are in fact racing with them, can you tell me if these transfer any LESS heat from the rotor into the caliper, as opposed to a more common racing pad like the Hawks?
I appreciate your thoughts on this.
Ed
Ed
Supporting Vendor
St. Jude Donor '11,'13
Thank you,
Ed LoPresti
Thank you,
Ed LoPresti
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Regards,
Steve
Steve,
I am certain you are correct - better leverage, AND a more efficient heat-sink.
Since you verified the sizing issue, I'll sleep better tonight. Thanks for your help!
Ed
Ed
We will be using Goodyear medium-compound, bias-ply slicks for most of our testing. (high torque stuff!)
I will be very interested to hear what you have for the J55 setup, especially if the "Carbo" portion of CarboTech refers to kevlar, or other aramid fiber impregnation in the pads.
If you like, please telephone us at 607 [-] 535 [-] 4237 (NY) to discuss.
Best regards,
Ed
We are seeking actual information here; so if, in fact, Hawk Blues are "old school", precisely what makes the CarboTech so innovative?
Thanks,
Ed
fade resistant to around 1700deg, non corrosive dust and easier on rotors. the hawk ht10 is a great pad too, it's just both are better than the blues which cost similar. racing is all about maximum bang for the buck. it's not that blues are bad, it's just why consider them when if you stay hawk the ht10 is better and the carbotechs are less corrosive. if you really want to spend a lot and have a high hp car with really sticky tires the hawk dtc60-70 is probably the most aggressive pad you can put in a j55 caliper. ALL of these are going to vaporize your rubber piston booties by the way
there's TONS of track info on here, honda tech, my350z, and the bmw forums.
in fact there are a ton of threads right here in the road racing section like
http://forums.corvetteforum.com/auto...s-dtc-60s.html
not sure why you needed me to spoon feed you
here's another direct blue / ht10 comparison
http://www.honda-tech.com/showthread...highlight=hawk
if you wanted to get scientific look up the friction co efficient of them all and the torque/heat charts
We truly appreciate well-considered and carefully thought opinion. Something like this offers real examples and has tangible substance.
And then there is this:
I did not think I was asking to be spoon-fed anything, and I certainly was not requesting condescending comments. Your first post on this thread really did not say much - at least 1 or 2 facts would have helped.
I was curious as to why you felt the CarboTechs were so much better that the Hawk Blues. Now I know.
Ed
Ed
No problem. I did enjoy reading on those links you provided.
One of the items I wanted to check with Adam was actual transfer of heat through the pad from the rotor to the caliper (and therefore to the fluid.) When we were campaigning our old 911, we found a fairly inexpensive pad, impregnated with kevlar, that tended to isolate the heat from the rotor, which also helped to reduce fade. We have been unable to find something similar since.
Ed
Ed
Supporting Vendor
Ed
Ed
Ed
there's really no pad that does the street and road course. the closest you'll really get is a hawk hp+ carbotech ax8 or axxis ultimate {if they are even made for the c4} all 3 of those have a great cold bite and can withstand a decent amount of heat given what they are.
I very much enjoyed our conversation, and hearing about your product offerings. We are sincerely impressed with your knowledge, and with the depth of your inquires. I have gone from skeptical (at best), to being anxious to try something "new". I am particularly intrigued by the thermal isolation from the calipers, which we find difficult to achieve with other commercially available products.
I am certain we shall be speaking more in the near future.
Ed
