change fuel filter
not a fun job but deffinantly do-able. just need to play around with the wrenches till you find a position they work. alot easier with the exhaust out if you had any future projects coming up that require exhaust removal?
simple, once you know the tricks.
Make sure to release fuel pressure and disconnect battery before you do this. Also, do it with car/engine cold. Best time is to let it sit over night in garage or whatever and do next day.
1st Loosen the fuel lines behind the fuel filter that attach them to the car. This will help with some slack. Also, loosen the fuel line that goes forward of the fuel filter to the fuel rail.
2nd Loosen the rear most fitting on the fuel filter with a crowsfoot wrench then unbolt the bracket holding the filter.
3rd Carefully from the engine compartment pull the filter and line assembly up through until you got free access to it. Then using a regular line wrench, take it off.
To install reverse procedure. Hook up battery and prime system by cycling key a few times. Then check for leaks, if not, fire it up. Done.
I could not get the top nut of the filter loose when I first got the car and tried couple times. Tries all kinds of wrenches but could not get enough power or leverage to turn it. I ended up changing the filter when I changed the starter shortly thereafter. With the starter out it's a piece of cake to do. I bought the tool for the fuel line separation so I am all set to go for the next time.
Cruising
As far as the clearence issue from the top to get a wrech on the fuel line I ground out a slot in a 16 point wrench to fit over fuel line (instead of the normal 8 point fuel line wrench) which gave me more adjustment to break loose the fuel line from filter - the whole fuel filter replacement took about 2 hours - but that was the first time I had done it and had read horror stories about twisting fuel line. Oh I also removed the inner fender well to have a better access - jim
Cruising
You must be a prodigy mechanic -
WTF- I guess I must be an old man (I would never start a message using that)
Anyway I am glad it only took you a half of an hour - it took me that long to jack up car and crawl underneath (proves that I am an old man) I guess the reason I am replying is that I really don't think I should have been flamed like that on a public forum.
Jim
Jim
Jim
Jim
