Blown head gasket or something else?
The last time I had my track car out it started smoking very badly (white smoke). I did a compression check and all cylinders are at 165 PSI except for number 2 which is at 90 PSI. Also when I pulled the plug on that cylinder it puked out coolant.
I just pulled the intake mainfold and I have coolant in the intake manifold valley too.
I'm getting ready to pull the suspect head right now but just wondering if there is anything else I should be checking?
How obvious will a blown head gasket be?
Thanks!!!
Thanks!!!
i was able to see the pictures,damn that's ugly ! but hopefully nothing major
happened to me some years ago.
like tblt44 said, check the head's surface just to be safe
