Oil leak around dipstick tube
Old 05-16-2011, 10:13 AM
surfer93
surfer93's Avatar
Default Oil leak around dipstick tube
Everytime I rev my engine above 2k, I get a cloud of smoke and a nice oil sheen on the passenger side of the car.
I know I am leaking oil around the tube, but I also see where oil is coming out of the top of the tube.
What is causing the oil to go up the tube?
PCV valve has vacuum and seems to work right, with no air leaks.
Old 05-16-2011, 11:01 AM
0Paul Ruggeri
Former Vendor
Paul Ruggeri's Avatar
Cound be excessive blow-by caused by worn rings. With the engine running pull the PCV valve out of the valve cover. If you see little puffs of smoke coming out of the valve cover, that's your problem.
Old 05-16-2011, 12:24 PM
Kubs
Kubs's Avatar
Received 1,754 Likes on 941 Posts
2023 C5 of the Year Finalist - Modified
St. Jude Donor '09-'10-'11
I had the same problem last year. I am rebuilding my engine now.
Old 05-16-2011, 01:54 PM
mdlfcrss
mdlfcrss's Avatar
Possible pressure building in the crankcase? If there's no breather on the valve cover, maybe the pressure will push up the dipstick tube and spray the exhaust, hence the smoke? Just a thought...
Old 05-16-2011, 04:17 PM
96GS#007
96GS#007's Avatar
Received 1,741 Likes on 1,049 Posts
Make sure that the PCV valve hose and the line that runs to the throttle body are in good condition...ie not soft and collapsing. As a last ditch effort, change the PCV valve as well.
If none of the above works, you probably have blow-by and it's time to start shopping for parts.
Old 05-16-2011, 09:49 PM
dizwiz24
dizwiz24's Avatar
If you think your engine is fine, and you get good compression readings, then simply replace your oil dipstick w a brand new one (gm).
That was the prob w. Mine.
No smoke, no issues.
Old 07-16-2011, 02:37 AM
grantar2
grantar2's Avatar
by the way at high RPM 4K + do you see any smoke in the car?
grantar2
grantar2's Avatar
Why would ring blow by show up at the dipstick?
Old 07-16-2011, 03:54 AM
96GS#007
96GS#007's Avatar
Because it pressurizes the crankcase which forces the oil up and out of the dipstick tube.
To Oil leak around dipstick tube
Quick Reply: Oil leak around dipstick tube
