OBD II socket replacement
I noticed when I got under dash to hook up OBD reader that it was dangeling from its mounting point (looks like the ears where screw makes attachment broke off) - Has anyone changed this before? I was wondering how hard it would be to change. It has the OBD II socket but I guess it is read with an OBD I software.
Thanks in advance
Jim Sawyer
1995 C4 -
Thanks in advance
Jim Sawyer
1995 C4 -
Changing the connector with some electrical experience is not a big deal to replace. The OBD2 connector used on 94-95 with OBD1 system. Yes, some sort OBD1 software is used.
The on board diagnostics do work great.
Obtaining the correct connector might be a challenge to get.
Thanks in advance
Jim Sawyer
1995 C4 -
Thanks in advance
Jim Sawyer
1995 C4 -
Along this line of discussion, I have a 96 with OBD II connector, and I understand that it can be read with an OBD II diagnostic device. I have two such readers, and neither one can get anything out. When I look at the pins, I have wires on pins 2,3,4,6,9 and 16, as I believe I should, but I also have several extra wires on some other pins. pcolt94 mentioned "on board diagnostics". Can anyone tell me how that works?
Your 96 is a OBD2 system and a OBD2 scanner should work. From what I know and others that have posted on the 96, the on board diagnostics does not work as it does for the 94 and 95 models. I do not own a 96 so don’t have first hand information. But I believe a scanner is necessary to get the codes for a 96.
I don’t know why you are having a problem getting the codes with your scanner. I would first test the scanners on another OBD2 car and see if it works. If it does there might be a problem with your 96. Make sure there are no pushed pins in the connector and not any broken wires behind the connector.
What does your scanners do? Do they say anything about a communication error?
I will have to try it again tonight and see exactly what it says. It powers up, but it says something about can't find a link. I'll respond with exactly what it says, after I retry it again tonight.
