Intake Manifold Gasket failed?
2nd Gear
I have a 1990 / L98 Coupe
After the engine has been running for a while there is smoke coming from underneath the car. Smells like oil. I suspect dripping on the exhaust pipe.
After running and the car is in the garage, there is a smell of coolant, but I do not see any leaks. I do not seem to lose any coolant. Small amount of steam/very ligh smoke coming from distributor area.The car always runs at 160 due to a previous owner installing a performance chip.
I don't know it is related, but I have small drips of transmission fluid on the garage floor.
My guess is that the intake manifold seal/gasket is bad and needs to be replaced. My only concern is the real problem intake seal, main seal, etc.
Does this sound like I am on the right track and how can I be reasonably sure which is the problem?
Thanks for your help!!
valve gaskets, oil senders -2- and the tee, also dist gasket can all leak. if it is burning you can trace it pretty easy before making a major repair.
2nd Gear
Oil / Coolant leak
oils and coolant odors sounds like intake gaskets. I have heard that you can retorgue intake bolts to spec -or close- 35 ft lbs, and can solve the coolant leakage. if yours are not nociceably loose that prob won't work. esp center bolts. these are sealing gaskets and don't blow out.
Thanks to all!!
I don't know if it still existed in the '90 cars, but on my '86 there is a small tube and hose that goes from the heater bypass valve over to the back of the intake manifold near the distributor (passenger side). On my car the hose developed a pinhole leak that would only happen when the car was hot.
