J55 Heavy Duty 13' Break Rotors
Hi Guys! I need sum help with a C-4 to C-5 break up-grade? on the 1996 corvette the front rotors are J55 13' stock and I am wanting to use the C-5 calipers (Fronts) with the J55 Heavy Duty 13' drilled and slotted Rotors? can this be done? Thanks Bornwild.
And you will need c5 rotors, can't use the c4 rotors. the "hat" offset is different.
J55 Heavy Duty Rotor's
O.K.! I know about the brackets? But what about the C-5 calipers fitting the J55 Heavy Duty Rotor'r in the front? Thanks Bornwild.
