Autolite Spark Plugs
Ok, I have a stock 1992 LT1 Corvette. I installed Autolite Copper Core Resistor plugs and gapped them to .035 because that is what the Autolite website said for my application. I am still working on the car and have not fired it up yet. I noticed that the factory plugs are gapped at .050.
My question is, is the .035 gapping for the Autolites wrong? If so, what should I gap them to?
Thanks!
Thanks!
For performance applications I believe that .010 less than the factory recommendation is fine. Remember, the factory establishes the gap based on available voltage, emissions longevity requirements, mileage and performance. For pure performance applications the smaller gap is better. Although less of the mixture is exposed to the spark the spark is hotter without needing a different heat range plug. That's a good thing. I'd go with .040.
Are you saying the plugs you took out are gapped at .050? Some erosion of the plug electrodes is normal. Gunny has a good suggestion of a good compromise.
If your fuel is fully atomized, a smaller gap is fine. It will make a fatter, hotter spark. Less gap = less resistance. less resistance = more amperage. more amperage = bigger boom.
When saying .050, I was referring to the GM sticker under the hood.
I did decide to keep the plugs at .035. Didn't feel like pulling all the plugs just to re-gap to .040.
Thanks for your help guys!
Moderator
CI 5-6-7-8-9-10-11-12 Veteran
St. Jude Donor '09-'10-'11-12-'13-'14-'15-'16-'17-‘18-'19-'20-'21-'22-'23
I'm running a set of Autolite 606's (copper core) in my '93. Can't remember what I gapped them at, but I have no problems with it running or starting.
What's interesting is that on Autolite's website they list the 106's for the LT1 from 1992-1996, but list the gap as .035 for 1992 and the gap as .050 for 1993-1996.
As far as I know, 1992-1996 LT1's were identical.???
