700r4 swap with non-vette 700r4
Hi, Im new to the vette world and Im hoping someone could shed some light on my 700r4 issue. I have a 85 vette with a 700r4.
1- will my 700r4 from my 88 firebird work?
Is the corvette transmission shorter?
2- will the driveshaft be 2 short?
3- will the tailshafts interchange?
4- if the tailshafts do interchange, will the holes still match up on the
c-beam?
5- Is it possible to drilll or notch the c-beam holes out and use the old driveshaft.
6- Is anybody using a non-corvette 700?
thx
c-beam?
thx
The vette tail shaft has about 5/8'' removed, so you could cut the tail shaft on the firebird 700r4, swap over the tailshaft housing housing & speedometer parts. Everything should fit fine.
Make sure the tranny is for a v8, b/c they made th700r4s for the 60*v6 which has a different bolt pattern.
The Corvette has a completely different valve body. The case has a big "V" cast in each side to show this.
The other main difference is the tailshaft housing, which is specific to the Corvette because of the C beam. I would think that the tailshaft housings would swap. I think the output shaft in the Corvette 700r4 is a different length also (because of the tailshaft housing - not sure about that one).
The servo is also different, but those can be swapped. The Corvette servo has a larger apply area on the piston.
Forum trans expert Pete K says every swap he did needed the shaft cut.
Speedo drive gear needs relocating to the rear hole on the output shaft of non Vette trans when swapping the tailshaft housing over
YES
YES
NO
YES
4- if the tailshafts do interchange, will the holes still match up on the c-beam?
Completely different style housings , must use Vette housing to fit C Beam
YES
YES
NO
YES
this is excellent info
What kind of Firebird was the doner? If it was a 350 TPI it will have the good Corvette valve body that allows WOT operation in fourth gear. If is a base transmission it will not hold fourth gear at WOT.
700r4
Thanks guys for the great info. I was still wondering, if the tailshafts are interchangeable, (will the c-beam holes still match up?) It seems that if the transmissions are shorter the c-beam holes would be "off".
Am I mistaken
Am I mistaken
The transmissions are the same size. The output shaft of the f-body needs to be whacked 5/8" (use a cutoff wheel). Use the C4 tailshaft housing with the f-body transmission. Change the location of the speedo gear on the output shaft. That should do it.
My experience is that Vette tranny has many special parts not in other non-vette 700R4's. Yes, you can swap it and it will work, but it will NOT shift like your old vette tranny used to. Ask me how I know...
I ran a 700r4 from a full body Impala. With a transgo shift kit, it was fine.
All C4's with a 700 R4 had a specially calibrated valvebody.
Trans Go shift kit does not over ride all factory calibrations.
Only the 2-3 reprogram kit will set up for Full manual valvebody operation for drag race use does over ride all.
1986 to 1988 IROC CAMARO's are rumored to have same C4 Corvette valve bodies stock.
And the 1987 Pontiac Trans Am GTA.
The real test is the WOT 3-4 automatic upshift.
does it take place or not.
All stock C4's did this.
And held 4th gear till the driver let off the gas pedal.
BR
BR
I am actually considering an 89 Trans Am 700R4 for my 89 vette.... was the B&M and shiftkit needed to hold overdrive or would it have worked stock with the output mods ?
From what I've seen of a line pressure chart in the FSM, the Corvette version of the 700r4 has higher line pressures than the ones used in other cars. You can change that with a shift kit.
One thing I think is interesting is that the line pressure chart in my '86 FSM does NOT show the MD8 Corvette version.
I don't know where you are located or if you would be interested but I have the original 700R4 out of my '85 that was rebuilt about 10000 miles ago. I replaced it with a 500 hp trans from Monster because I also upgraded my engine and was afraid the original would not handle the power. I am in central Illinois and pickup is the only option, I will not ship. The original converter was replaced at rebuild time and the new one is included.
