c5 wagon wheels ????????
Don't forget to check the distance from the ground to the center of the wheel. I've seen cars with giant wagon wheels that sit several inches higher than normal.
Here are the factory offset specs...find your car's original offset and compare to the "wagon wheels" offset... FYI, 25.4mm = 1 inch
So if your car originally had 56mm offset and the new wheels have 80mm offset, 80-56=24mm that is 1.5mm short of 1 inch adapters..
I am planning on putting these on my 86.
