1988 Bose amp Schematics
Does anyone have schematics for the 1988 Bose amps? I have the squeal in mine and would like to know what caps are causing it?
I am still looking for where my info is. I did find this link which is for a 1991. I know that the units were different by then but I don't know if the capacitors that failed are the same.
http://www.zr1netregistry.com/Bose2.pdf
I have looked at that one also. From what I am gathering it is the caps that cause the problem and if were to replace mine, what would it hurt? Nothing ventured nothing gained.
Thanks for the link.
Here are some links from when I contemplated the project. I decided to dump all the Bose, no regrets.
http://12.212.62.128/old_proj15/old_proj15.html
http://www.zr1.net/amp.html
http://www.zr1.net/Bose2.pdf
https://www.corvetteforum.com/techti...D=91&TopicID=2
https://www.corvetteforum.com/techti...D=58&TopicID=2
Agent 86 thanks. What did you replace yours with? I have a 35th Anniversary and want to keep it all original. I have also sean that people are getting amps form some Mazda 929 Bose.
