what hiflow cats are best for lt1 exhaust?
The factory LTx cats actually flow very well for stock units. IIRC, the factory cats attach directly to the exhaust manifolds and one outlet is a slip-fit to the exhaust and the other side is a bolt-on flange.
Most aftermarket high-flow cats will require cutting off the old cats and welding in new ones. And most muffler shops will not remove a cat that is working even if you are replacing it with a different version. If they would get caught, they could face a 5-figure fine from the feds.
Since my 92 is now considered "Historic" in my state, cats are no longer required. (no more inspections or tailpipe sniffing)
When the time comes, she will be getting stainless long tubes, cat delete, an x-pipe, and as yet undetermined SS mufflers.
This what I've been using cost/performance is very good.
http://www.hottexhaust.com/search_re...2&txtCatName=2
But have they gone up in price. 6 years ago, I paid 69.00 each. FWIW I mounted mine where the resonator was. With a automatic, not enough room to get them directly off of the header.
I use Random Technology bullet cats with my headers and Corsa exhaust.
Pic of cats attached to the pipes that link the headers to the exhaust...
