1991 L98 won't start
Hello and please help.
I am a new first time Corvette owner; I purchased the car a couple of weeks ago. I started fine when I bought it.
I noticed the oil temp gauge wasn't working and the TPI coolant lines were bypassed. I changed out the temp sensor and rerouted the coolant lines at the same time, now the car won't start. It turns over fine, but won't fire up.
I bypassed the coolant lines off of the TPI and still won't start. Not sure what to do. I don't seem to smell fuel... not sure where or how to start.
Not sure whe the TPI coolant lines was bypassed, but am sure it has to do with this problem.
Bob
Bob
Thanks for all the help.
Thanks for everyones replies... I eneded up running the OBD and got a C41 code. Calls out an open to the ECM. Got one out of the junk yard for 50 bucks, changed it out and it runs ionce again.
Bob
Bob
The throttle body bypass is done by many vette owners. The coolant is circulated through the throttle body to keep it from icing over in very cold weather. If you are not worried about that, then it is a little beneficial to do the bypass, which keepas the air entering your engine at a lower temperature; thus, creating s tiny bit more power. It does clean up the engine bay a little and makes it easier to work on, if you have to remove the throttle body in the future.
