help needed with code 43 ESC failure
According to my scanner I am getting no knock counts from my knock sensor as I am driving although I am getting some knock retard. If I remember correctly the knock sensor would show counts as I drove around previously but last night the car threw this code at me. Any duggestions? Shouldn't I see knock countsn at all times? I think my retard is coming from my noisy aluminum flywheel setup because after a second or so after stomping the gas I get 6-8 degrees of retard and after a second or so it goes back to 0. :confused:
Re: help needed with code 43 ESC failure (AS84)
fixed it, I got underneath of it and the friggin' connector was off. hooked it up and I'm pretty sure that cured my problems.
