R&D Racing Cross Bar as a Harness Bar
Hi Folks,
I have a R&D Cross Bar in my car and I am planning on adding harnesses. I autocross and track the car.
My Cross Bar has a sticker that reads something like "this device is intended to increase vehicle stability and we recommend using factory seat belts".
How many folks are using the R&D Cross Bar as a harness bar? Anybody have any crash experience with this setup?
Thanks in Advance.
Thanks in Advance.
I am using a cross bar as the race belt mounting attachment point. It is not an RD but very similar. Thankfully, no real world test experience, but the belts mount perfectly.
I run one and absolutely love it, I didn't install it though. Previous owner did. Come with an sweet plate for mounting a camera also. I can't say that i've noticed the car is more rigid or anything because it's always been there, but it does make a great spot for mounting the harness
I have a home built one mounted the same way and modled after the R&D bar. I would say it does very little in terms of increasing stiffness, if anything. My sole purpose for adding it was to mount the harness.
As for stiffening the car, not too much on the coupe, but the convertible model helped tremendously. I have since installed a roll-bar set-up in mine eliminating the need for the "cross-bar''.
The convertible "cross-bar" is different from the coupe. do not interchange. I sold mine years ago here on the forum. Not even sure if RD racing even makes them anymore.
