What is the best C4 Sway Bar?
Looking to, slowly upgrading my '91's suspension for autocross and would appreciate some input before I order a new set of sway bars. My ultimate goal is a full coilover suspension.
Who has the best sway bars for autocross?
What are the current bars on the market, Van Steel, Mid America, Corvette Central, Ecklers.... any others?
Are these better than old stock and why?
I have heard from the forum that the full coilovers are expensive and not the best way to go due to tuning issues, but from the discussions with professional racers given the choice of the stock fiberglass springs and going to coil overs, the go with coil overs. So I am kinda set on coil overs.
That said, any input on the sway bars?
Thanks, Polo
Thanks, Polo
Max G’s
Vette Brakes, VB&P, specializes in suspension components.
If you are just starting to autox, learn with the stock suspension before starting upgrades. Once you learn to drive, then start your upgrades.
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09-'10-'11-'12-'13-'14-'15-'16-'17-'18-'19-'20
Contact Van Steel and speak with Paul.
I guarantee you great customer service, support and Vette parts
www.vansteel.com
www.vansteel.com
To all, I am past the novice level at autocross and starting the build on the car. So the 32mm front and 26 rear is the same as stock and the stock appear to be tubes. So are the repacements any better? How about the solid bars, while they add weight are they any better?
Thanks, Polo
Thanks, Polo
Thanks, Polo
Thanks, Polo
Thanks, Polo
Thanks, Polo
What class, restrictions on the class?
So if you call VBP and tell them what you want to do with the car they will sell you a suspension package.
Or you can call the recyclers and see if they have a Z07 suspension laying around. Or just the sway bars, or go adjustable, etc. Etc ETC
If you are so seasoned you should know by talking to other drivers that 32 & 26 are not stock.
Max G’s
Thanks, Polo
Thanks, Polo
The best? A custom made adjustable bar.
Go with tubular bars and save yourself some weight. I made a thread about rates here:
http://forums.corvetteforum.com/c4-t...l-options.html
Here are some pix from my last event in fall showing how the 1.25" and 1" tubular bars are doing (can see camber too):
http://f-51gtphoto.smugmug.com/2011N...0538&k=TdXsNqZ
Hoosier R6's for tires, 1.25" and 1" tubular bars. Got them on a nice VBP sale.
BTW use heim links, especially for the rear bar.
The 85 Z51 suspension comes with F30mm and rear 24mm. Thats pretty good. I run the Z51 30mm front bar and the Convertible rear 22 mm bar. Keeps the rear end planted. You can get them cheap from the wreckers.
My car is a race car @2880 lbs. Handling is very neutral. I run 27psi front and 29 psi rear on R1's.
We're a little limited on sway bar selection. We could actually use something bigger than the old Challenge bars. The solution is to use stiffer springs.
Normally this is not something I would do. Then again you race the car you have. I went with the Hyperco springs from Corvette Central. Not only did the car get flatter in the turns but these springs also dropped the car a little.
I rune the Challenge springs with Z51 sway bars. The rear is adjustable. I normall get the same tire temps on the front and rear of the car.
Richard Newton
101 Projects
Richard Newton
101 Projects
Thanks, Polo
Thanks, Polo
[/IMG]
To All,
Again, thanks for the input this is great, and has given me some followup work, but here are answers to some of the questions;
I am running in NCCC class E3 9 the car has modified intake and a cam. In SCCA I run Super Sport Street Modified with street tires.
I checked the FSM and figured out that there were both tubular and solid swarbars used in the '91, but it did not tell me what I should have. I need to track down a sheet I have that lists the suspension specifics. That said I measured the swaybars on the car and the front is a 32mm and the rear is a 26mm and if my memory is anyway near working (51% posliblity of error) that was listed as the stock size. The '91 is a convertable which i believe makes a difference. With the different bar sizes noted in this thread I am at best getting confused (a very easy condition to reach).
To Indy, Sorry I don't have the manual with me for the FHBs and NYUs to figure out the acronym. Kindly enlighten me.
Again many thanks to all of you I am learning a lot, Polo
275-17 Front
315-17 Rear
28 lbs cold Front
30 lbs cold Rear
I'm maybe 1 or 2 lbs too high here. I'll know better after the next track day.
Inflation
If the center temperature is higher than the average of the inside and outside temps, the tire is over inflated -- try reducing the pressure in 2 lb. increments.
If the center temp is lower than the average of the inside and outside temps, the tire is probably under inflated -- increase the pressure in 2 lb. increments. Once the pressures are set correctly, then look for major differences in temperature side to side.
Richard Newton
315-17 Rear
28 lbs cold Front
30 lbs cold Rear
Inflation
Richard Newton
315 square
Still felt a little too much understeer so recently changed springs, super stiff 84 z51 in front, z51 stiff in back , sore guts inside
Haven't had a chance to test it yet.
315 square
