Symptoms of bad MAF Burn-Off Module
Hey everyone
I have a 1985 Corvette and just learned yesterday that only the 85's have this MAF Burn-Off Module located behind the dash pad (not that I took off the dash pad yet because apparently it's a real pain in the butt?)
Can someone tell me the symptoms of a bad MAF Burn-Off Module? My check engine light does not come on (it works though), and my car doesn't die when running. But it idles funny sometimes. After the car has been running for a few minutes, the idle jumps up and down and it's very annoying. I changed the IAC recently too.
Is it possible that the MAF Burn-Off Module needs to be replaced? Any information/input would be appreciated, as I know these aren't so easy to find at a good price.
Thanks!
Thanks!
Is your up and down like this ?this is my 85...
http://www.youtube.com/watch?v=kG2W1...1&feature=plcp
The burn off module is only to clean the maf sensor by heating up the thin wire to burn off any contaminents.. I don't believe this module could cause the engine to hunt. If you already replaced the IAC, the next thing I would check would be to see if you have any vacuum leaks..WW
When my tps went bad the other day it would jump to 1400 rpm or higher then finally go back to normal. After it did that a few times at a drive thru it lost 1/4 of the gas pedal about 4 miles down the road.
This thread is 3 years old , he probably got it fixed by now.....WW
Received 1,400 Likes
I have the same :
