What are those 2 relays behind the battery on my 1989?
Hello all,
I have a 1989 with an intermittent starting problem. Once I start it up, it will run fine. Shut it down and it will start again most of the times. However, sometimes it just cranks and doesn't want to start. I do hear the fuel pump turning on, but it's still not starting.
I knock on both of the relays mounted behind the battery, and it will start right up. I think one is for the fuel pump, but what is the other one for? Pretty sure that "other one" is the culprit. Which one is the fuel pump relay?
Thanks in advance!
Thanks in advance!
The two relays behind the battery are the MAF sensor and the MAF burn-off. The fuel pump relay is over more , towards the booster. I changed my pump relay because it was intermitting, I actually changed all my relays. The one on the well near the Batt. is the main fan, the one by the radiator is the back-up fan. You will have running or starting problems if the MAF relays are bad, change all 5 so you have no worries.
Thanks for the info. That helps a great deal! The MAF sensor and MAF burn-off relays are the same part? They physically look the same. I haven't pulled them out as of yet.
I will take your advice and change all 5, so that I won't have to think about them anymore. Any recommended vendor to order from? Looking quickly online, they are relatively inexpensive, and a number of vendors have them in stock.
Thanks! I will check with NAPA on the relays. Yes, I agree.......probably best to change them all so that I won't have to think about them again. Thanks also for the tip on unplugging the relays.
Thank goodness for this forum! Great info from the experts!
