J55 caliper onto JL9 caliper mount bracket
I have a Datsun 510 here in Australia with the J55 calipers and custom 13" brake rotors.
i would like to downsize to a 12" rotor and would like to know if the J55 caliper i have will work with a JL9 caliper mount bracket and a custom disc to suit.
Are there any photos that show the difference between the J55 mounting bracket compared to the JL9?
Thanks in Advance
Panos
Thanks in Advance
Panos
GrandpaC6 (07-24-2023)
What do you call the mount bracket?
The abutment bracket that the caliper locks into with the pin through the pads and then that whole assemble is bolted on to stub axle
If so NO ;
the J55 abutment bracket is wider and the J55 caliper would not fit correctly into the narrower JL9 bracket.
If you are after retaining the 28mm thickness of the J55 rotor, your would just reposition the J55 rotor and it's bracket 1/2" closer to the center
( what stub axles is being used ? )
Easily done if you already have custom adapters on a non Vette stub axle
Have both types on the shelf ; can confirm measurements for you later
If so NO ;
If so NO ;
If so NO ;
looks like i need to go a different route with the brakes..
Uploaded with ImageShack.us
