TPI idle vacuum?
06-18-2012, 01:18 PM
Holley HP EFI w/TPI
TPI idle vacuum?
I've just installed a TPI intake onto my '70 block, running Holley HP EFI.
What is the TPI idle vacuum normally?
06-18-2012, 01:21 PM
I might be off base but isn't the cam a variable in the amount of vacuum you have?
06-18-2012, 01:22 PM
Holley HP EFI w/TPI
06-19-2012, 01:09 AM
Mine measures 15 inches at idle, hot. Stock everything.
06-19-2012, 07:36 AM
With my stock engine mine was 17 in at idle. I would say anything within a few points of this would be ok...WW
06-19-2012, 03:16 PM
Holley HP EFI w/TPI
That's about 55-60 Kpa, give or take, I think I'm in the mid 40s right now.
Once I set my timing, I'll verify, thanks!
