Think the STARTER is BAD
Came home the other day from a long ride and shut it down. When back out to leave again with it and it wasn't starting. Had all the symptoms of a bad starter. (Replaced this 4 years ago).
Anyway I pulled the starter off today and found this.... I say its no good.
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
A little JB weld and she'll be as good as new...
You used it as a sledge hammer before mounting it on the car, didn't you?
well my starter is preatty beat up. isthe original starter. I have a lot of issues with it. when I got my vette. finally I rebuild the hole thing. some times stock. but work.
the thing . my starter is 26 years old. and is not crack. i think you better make sure why that happend. we dont want the same thing happend to the new one
When I put the current engine in my 92 the stock replacement starter lasted about 4 months before the nose cracked.... got another one and it only lasted 2 months before the same problem.
This is what I'm running now.
http://www.summitracing.com/parts/PWM-9502/
Will
Will
