Coolant change help! I am in the process right now...
and I can't decide how to loosen the radiator drain plug to drain the coolant into the pan without getting a faceful of it myself...
Re: Coolant change help! I am in the process right now... (marthpodi)
Nevermind, I see it. Problem is, there is some sort of big hose in the way. I'll try to snake my arm around it and loosen it from the top, thanks!
It's a tight fit, but my 94's drain plug can be reached from the top.
[Modified by STL94LT1, 4:03 PM 5/26/2002]
Re: Coolant change help! I am in the process right now... (STL94LT1)
Ok, got all that done. New Question: How do you remove the Coolant Reservoir?
anyone? I can't seem to find how to take the hose off and remove the coolant reservoir to flush it out.
