Normal Coolant Temp/Oil Temp/Oil Pressure
Received 1,400 Likes
Re: Normal Coolant Temp/Oil Temp/Oil Pressure (marthpodi)
pressure 50-65psi at cruise or under acceleration
oil 190-215 is best
coolant, about 15 degrees below the oil
oil 190-215 is best
Re: Normal Coolant Temp/Oil Temp/Oil Pressure (vader86)
oil 190-215 is best
oil 190-215 is best
Location: 10.70 @ 124mph, Stock Bottom End @ 3620lbs, ECS Racing Team Member. The 1st NMCA LSX Index Rumble World Champion. 2011,12,13 Champion
Re: Normal Coolant Temp/Oil Temp/Oil Pressure (Bluevette85)
Oh No, I have 45 psi of oil pressure cruising and 13 to 15 at idle when hot (180). I guess I know my next project or just add it to the list. :rolleyes:
