Fuel pump by Ecklers
I'm sure they just get them from another supplier and stick them in a box. As suggested, call them.
1 Post
I have a P-1SC, FMU , 44 lbs injectors, heads, cam etc. Between 5500-6000 rpm at wot, the fuel pressure drops from 75 psi to 65 psi, duty cycle was 82 %, I removed the in-line pump, nothing change. Next i removed the in-tank pump and return the in-line pump, nothing change. I think next i put a 255 L/hr Walbro in-tank pump alone.
