1989 Vette - Distributor Ignition Module
Old 07-29-2012, 09:52 AM
glewis954
glewis954's Avatar
Default 1989 Vette - Distributor Ignition Module
Distributor Ignition Module - does this need a conductive gel as part of the install? I purchased a module from a local parts store, but I didnt
get one in the kit.
Old 07-29-2012, 11:01 AM
raiderz
raiderz's Avatar
get one in the kit.
Yes...use dielectric grease and spread it on the bottom plate generously. Just did mine a few weeks back
Old 07-29-2012, 11:54 AM
glewis954
glewis954's Avatar
Thanks .. I thought I was missing this when I purchased the mod
Old 07-29-2012, 12:11 PM
Hooked on Vettes
Hooked on Vettes's Avatar
You want to use a heat sink thermal paste/grease. Usually
White in color. This allows the ignition control module to transfer
the heat to the distributor base.
Available at Radio Shack or most electronic stores.
http://www.radioshack.com/search/ind...+compound&sr=1
Old 07-29-2012, 12:26 PM
higgyburners
higgyburners's Avatar
I believe in the Beer Fairy
St. Jude Donor '15,'19
I agree dont use the dielectric grease for this job, Use the Thermal paste.
Old 07-29-2012, 02:44 PM
raiderz
raiderz's Avatar
Probably explains why my module burned out after 26 years....should have used the thermal compound
If you are going to go to that extreme...you might as well get the silver paste called "Arctic Silver" ....the white stuff is good for diaper rash
Old 07-29-2012, 03:02 PM
higgyburners
Its more than likely thats what your car came with, I just changed mine out and the new one came with thermal heat sink paste. Dont take my word for it do a search here on the forum....if you feel the need to be vindicated.
Old 07-30-2012, 10:54 AM
JohnMC1125
Cruising
JohnMC1125's Avatar
Quick question fellas. I have heard this module can be behind hard to start and no starts on hot days or when the car is hot. Is this true?
Old 07-30-2012, 11:07 AM
TorchRedlt4man
TorchRedlt4man's Avatar
Location: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Yes, that is correct.
There are other items that will cause a hard to start/hot day/hot engine no start.
Old 07-30-2012, 09:41 PM
WW7
WW7's Avatar
A bad ICM can also cause the engine to shut off and stop running at any time "Like on the highway going 70 mph"..Ask me how I know.......WW
Old 07-31-2012, 06:51 AM
glewis954
glewis954's Avatar
ICM is this the same as the ECM the Electronic Control Module. Also does anyone know were it is in a 1989.. Haynes manual shows it on the side of the radiator... Its not there.. Dont tell me its in the dash...
Old 07-31-2012, 07:47 AM
Keystring
Keystring's Avatar
On my 87 it's between the right fender and heater box.
Old 07-31-2012, 08:40 AM
glewis954
glewis954's Avatar
Ok.. I have check the right pass side .. I see were the heater core and the fender there is nothing.. one the side of the heater core housing next to the engine. There is two wire connector going in to the housing
could this be the ECM?? can you send me a pic of your ECM location ..
glewis954@aol.com
Old 07-31-2012, 09:38 AM
Keystring
Keystring's Avatar
Just to clarify.. the ECM (Electronic Control Module) is not the same as the ICM (Ignition Control Module)..
The ICM is under the distributor cap.
The ECM (or computer) is under the right side of the dash.
If you are talking about the ESCM (Electronic Spark Control Module)..
It's on the right side of the blower motor housing,left side looking from the front....(at least in my 87)
Old 07-31-2012, 09:49 AM
glewis954
glewis954's Avatar
Keystring
Thank you.. I have located all of the items.. ICM has been changed..
ESCM - ordering.. I am going to check for the ECM now.. Does the ECM
have to be programed if I purchase a new one???
Old 07-31-2012, 10:04 AM
Keystring
Keystring's Avatar
Keystring
Quite honestly, I don't know.. I've never had to change one.
Old 07-31-2012, 10:15 AM
glewis954
glewis954's Avatar
Thank for the information..
To 1989 Vette - Distributor Ignition Module
Old 07-31-2012, 10:22 AM
TorchRedlt4man
No programming is necessary.
You will need to remove your PROM (chip) from your old ECM and install in the new one.
Very easy to do.
Old 07-31-2012, 10:46 AM
glewis954
glewis954's Avatar
Very easy to do.
TorchRedlt4man
Thank you for the information..
Old 08-01-2012, 01:46 AM
Cliff Harris
Cliff Harris's Avatar
The ICM (Ignition Control Module) is inside the distributor.
You need to move the MEMCAL from the old ECM to the new one. It holds the program that runs your car. It's under a cover on the ECM housing held on by two 1/4" hex-head screws. It looks like this:
Quick Reply: 1989 Vette - Distributor Ignition Module
