89 Code 51
89 Code 51
Started the car tonight but it quickly stalled out. No check Eng etc. I attempted to restart but it would run for a few seconds then stall. repeated this 2-3x noticed that before it would stall that the upshift light would flash on and that when it would finally stall out the fan would run for a few seconds. checked for codes and got nothing. Started it again, ran for about 20 second, step on the gas to stop it from stalling and it backfired before stalling again but this time I was able to pull a code 51 (mem/cal).
Waited about 30 minutes, it restarted fine and idled it for about 5-7 minutes and drove it for a few block and no problems. rechecked for codes but still have the code 51
There is a lot of moisture in the air so I suspect (more like hoping) bad grounds to the ecm but tomorrow I plan on pulling out the ECM and reseat the mem.
Any helpful tips on pulling out the ECM?
Little history:
I've been fighting a bad idle, cleaned TB and put in new IAC but when I stop at a red light it will idle @ 900 until I tap on the gas lightly it will drop to it's normal 600.I've reset the IAC but still does this.
Also
http://forums.corvetteforum.com/c4-t...out-on-me.html
Little history:
Also
Check if the Memcal is seated correct. If you are lucky then this is a cheap fix. This may also help your idle issues.
Another thing to look at with your idle issues are vacuum leaks.
Also, did you follow the proper procedure for setting up the IAC and TPS?
Gunner,
this sounds like bad contacts. Thing is, could be anywhere. So many are critical.
I had similar issues when I reassembled the jumper post with dirty connections. Cleaned them and problems went away. Try that if you have the jumper post behind the battery. Thats the power source for ALL control, sensors, actuators and electrical. Its fusable link, not thru the fuse panel...
Of course do the typical ground set on the rear block over oil filter....
ECM pull.....10mm socket on 6" 3/8 ext on ratchet or cordless driver,. pull cables and other harness aside, Locate the locking tabs for the 2 plugs into the ECM,. Release gently without pulling wire out. Pull plugs down, out. drop the 2 10mm and lower the ecm. Inspect it for wetness, then remove prom to look for bent pins. Use soft wire brush to clean pins and re-install...or use spare prom if you have one. Pull cover off to do visual on rest of the ecm board.
Its not bad at all. Just be mindful of the old wiring,...much of it is dry cracked, so go easy!
Hope it helps
Hope it helps
