86 clutch issues
Old 08-20-2012, 06:00 AM
Sharrell
Sharrell's Avatar
Default 86 clutch issues
I took my 86 to the Woodward Dream cruise on Saturday (I was assume and Corvettes were well represented). Drove 10 miles from home to cruise and about 5 miles in stop and go traffic. When I went to park the car the gears started grinding in reverse and the clutch pedal was weak. When I drove home it was difficult to get shifter into gears. Any thoughts on what is causing this issue?
Thanks!
Old 08-20-2012, 11:24 PM
856SPEED
856SPEED's Avatar
check your fluid level in the clutch mater cylinder first. If it's low, you have a hydraulic leak.
Old 08-21-2012, 05:42 AM
Sharrell
Sharrell's Avatar
Thanks for the info. If there is a leak, where is the most common location in the system for a leak?
Old 08-21-2012, 08:34 AM
sailorsteve
Support Corvetteforum!
sailorsteve's Avatar
The system consists of a master cyl, slave cyl, and the connecting line. The cyls are the usual source of leaks. A master cyl leak may be hard to spot, sometimes leaks behind the carpet. If the fluid is low, I would fix the leak soonest because your trans will suffer if the clutch is not releasing completely.
Old 08-21-2012, 10:15 AM
coupeguy2001
coupeguy2001's Avatar
2021 C4 of the Year - Modified Finalist
clutch master cyl. can also bypass fluid internally, not pushing any or enough down to the clutch slave cyl. to push in clutch.
Old 08-21-2012, 10:32 AM
c4cruiser
c4cruiser's Avatar
It's also possible that the hydraulic line from the master to the slave cylinder is shot. The rubber portion could have failed on the inside which would effectively reduce the amount (and pressure) of fluid going to the slave. That would keep the slave cylinder from allowing the throwout bearing from fulling releasing the clutch.
How many miles are on the car and is the clutch assembly original?
Old 08-21-2012, 11:32 AM
Sharrell
Sharrell's Avatar
The car has 67,000 miles. I believe it is the original clutch.
Old 08-21-2012, 11:37 AM
sailorsteve
Other than gross abuse, that clutch should have plenty of life left. In any case, a leak should not be hard to spot from underneath unless the master is leaking under the dash. Check the fluid level first, if it's low, the system is leaking.
Old 08-21-2012, 12:06 PM
Sharrell
Sharrell's Avatar
Thank you all for the expert advise. The car is going up on a hoist tomorrow to have the overdrive unit fluid and filter changed. I will post futher info upon inspection.
Old 08-21-2012, 01:51 PM
383vett
383vett's Avatar
Received 1,541 Likes on 1,042 Posts
A worn clutch usually will slip. Your problem is that the clutch us not releasing. That would be almost always the clutch master cylinder or slave cylinder issue. Possibly your fluid is low as previously mentioned.
To 86 clutch issues
Quick Reply: 86 clutch issues
