5 pin HEI help
5 pin HEI help
I have a 84 that i did a carb conversion on, i got a mechanical/vac dizzy that has a 5 pin HEI module installed, The car is freaking out and sputtering around 3000RPM.. I think its the module.
I used the factory connector that went into the 7 pin module dizzy and hooked it up too the vac advance with the 5 pin module..
What do I need to do to eliminate the retard in the 5 pin module and does the large flat 4 wire connector need any modifications?
the 5 pin module has the knock sensor in it, if the 4 pin will physically plug in to the 5 pin plugs , that should eliminate the knock sensor cause there wont be a plug for it and the module wont be spazzing out. . and ...probly run ok. post this in C3, I've used the gm hei on fords , toyots, bmw's , honda's, etc. but as cheap as they are , I just go buy a complete dist, when it comes to chevy's. eliminates all the b.s.
W and G on a 4 pin HEI module just go into the pickup around the distributor shaft?
So if i just left the large flat 4 wire connector off it should work fine correct? problem is that it won't start if that is disconnected.. Is the ECU killing spark some how?
I know it doesn't do anything anymore, The only reason I said that is because the ECU and wiring are still in place for now and im not getting spark unless the EST is pluged in.
I replaced my MSD 6AL box with this summit box when it went out on me. No problems at all.
http://m.summitracing.com/parts/sum-850610/media
If you download the installation instructions and scroll down to the GM hei 4,5 and 7 pin modules you will.see how easy it is to install.
