stock cam specs???
stock cam specs???
What are the stock cam specs of an L98 cam in a 1990 Corvette? Can I put 1.6 roller rockers on it with no valvespring or valve to piston issues?
Re: stock cam specs??? (CarNDrvr)
Try doing a search on cams, it has been posted a few times lately. You can put 1.6RR's on L98 with out any problems or changing the springs. If you have high miles the spring maybe worn though.
