Tip: addressing split convoluted tubing
Old 10-03-2012, 10:34 AM
mixalive
mixalive's Avatar
Default Tip: addressing split convoluted tubing
A lot of people put electrical tape on the ends and at Y’s of convoluted split tubing to keep the wires addressed. But even with high quality tape, heat tends to melt the adhesive, leaving a mess. So I have this tip that has been working for me.
I first tape the tubing. Then, I take Liquid Tape and paint over the electrical tape, all around the taped joint, especially where the tape seam is. A second coat doesn’t hurt. This stuff dries super quick, looks great, and keeps the tape intact.
Old 10-03-2012, 10:57 AM
TTA579
TTA579's Avatar
I prefer using a zip tie. Very easy to snip and replace when doing maintenance.
Old 10-03-2012, 11:35 AM
1963SS
1963SS's Avatar
Thanks for the tip. Sounds great, I'll go get some and do my harness because the tape will eventually look like crap.
Old 10-03-2012, 12:22 PM
TorchRedlt4man
TorchRedlt4man's Avatar
Location: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Nice tip.
I have the liquid tape in my cabinet, but never thought of that particular use.
Old 10-03-2012, 07:23 PM
SJW
SJW's Avatar
Received 1,384 Likes on 917 Posts
Looks good to me.
Hmm... Gotta wonder how well that stuff would work for touching up nicks in the Duslo coating on the console shift plate... Might have to try it...
Live well,
SJW
Old 10-03-2012, 09:51 PM
Midnight 85
Midnight 85's Avatar
Finalist 2020 C4 of the Year - Modified
Nice tip, I have always thought about buying some of that liquid tape, now I have a reason.
Old 10-04-2012, 01:43 AM
Cliff Harris
Cliff Harris's Avatar
They do make high temperature electrical tape. I don't know part numbers or brands offhand. Scotch #33 is NOT high temperature.
I have found that it sticks better if you stretch it at the end of the wrap and don't touch the adhesive with your oily fingers. I have tucked the end of the tape back under the last loop and then pulled it until it broke. Tightens and secures it at the same time.
Old 10-04-2012, 10:16 AM
mixalive
mixalive's Avatar
And when the stretched tape gets hot, it will try to shrink back to it's original size leaving the "mess".
Scotch Super 33+ is rated for 220*F. It may not be considered high temperature but has about the best long term adhesion for outdoor use that is readily available to the consumer. Please share the link with the high-temp tape.
To Tip: addressing split convoluted tubing
Quick Reply: Tip: addressing split convoluted tubing
