94 Digital Climate Control
Just wanted to say a big thanks to those who have taken the time to describe how to fix the issue where the buttons stop working on the climate control. After running a search on here I found a thread that described how to remove the head and clean the circuit board with a pencil eraser and rubbing alcohol. Now works perfectly.
It always helps when you search for a fix and find it quickly.
94 digital climate control
Tried looking for the thread regarding the "pencil eraser and rubbing alcohol" with no success. Did see one with resoldering the contacts. Can you point me in the right direction ASJWALSH?
It worked for me too on my '94.
If anyone else is looking for how to do it, see the following link.
http://forums.corvetteforum.com/c4-g...on-repair.html
Good luck
Good luck
In this case, you will be unplugging an electrical connection to get the module out of the car.
When I did mine, I didn't disconnect the battery and nothing bad happened.
BUT, there is always that possibility.
That is why step #1 is all the manuals is to disconnect the battery.
I did unplug my battery just cos the fsm said to do it. It's only two minutes to do it and then a few more to reconnect and reprogram the radio channels.
It's still working beautifully.
