96 LT4 Spark Plug Gap
Spark plugs lt4
Hello guys,
i was changing the spark plugs and everything went wel till i hit cylinder 8.
Anybody seen this before? I ordered nee Delco’s cause there was no issue with then.
The tip is pressed down during installation. I used force but not excessive. Old plug goes in and out without this problem.
With the tip depressed they seem the same size. Gap is 0.50 on the bend one. Aligned on the point where it is seated in the head.
This is the new one i used, which got bend.
Check the overall length of the new pug (Un-bent) and compare against new. Next I would check to see where the piston is in the cylinder. Stick a plastic or wooden dowel in the spark plug hole and see if the piston is at TDC. DO NOT TURN TOUR ENGINE OVER UNTIL YOU FIGURE THIS OUT. I have a cheap bore scope from Harbor Freight that comes in handy for these types of situations. Also, check diameter of shoulder...they look the same however.
Also, the original plugs look to be good shape, why the change? The gaps seems a bit much. Read comments above in old thread. It seems gaps were reduced to 0.04". That seems like a more reasonable gap.
You also may want to start a new thread. This one is over 3 years old.
