1984 Corvette Stock Cam Duration/Lift
Title says it all. I'm wondering what my Cam Duration/Lift is. Thanks! Any suggestions on a good upgrade cam would also be great.
1 Post
Re: 1984 Corvette Stock Cam Duration/Lift (84Coyote)
The cams specs for 84 thru 86: Duration @ 0.050", 202/206, lift .403/.415 , Lobe seperation 115 degrees. Do you wish to mantain a nice idle?????
I am using a Crane Compucam 2030 with 1.6 roller-rockers with Edelbrock heads and an X-ram. I have a friend (Terry82) with an 82 vette that installed a Comp Cams XE256 with stock rockers and ported the intake. Both worked very well and worked with the stock computer. There are bigger gains to be had by switching to the '7747 ecm (which I have done). Check out this site. It is the best cross-fire site I have seen: http://www.crossfire.homeip.net:81/c...artdefault.asp
Check us out!
Check us out!
Re: 1984 Corvette Stock Cam Duration/Lift (compuvette)
i have a summit k1102 which is a clone of the compu 2030, im also going to add 1.6 rockers, and shooting for 270hp, with head work and exhaust
at the crank. Im looking at spending no more than 700 bucks, you'd have to look at a setup similar to domnics, he made just over 270 at the wheels
