Replace shocks on 94 c-4
Old 02-18-2013, 11:13 AM
Nocrsis
Nocrsis's Avatar
Default Replace shocks on 94 c-4
I'm replacing shocks on a c-4. I have replaced shocks on many cars but never a vette. Seems to me that rear shocks have to be replace in a certain way or you could mess up rear suspension. Is that true and does any body know how? I'm replacing old shocks with new bilsteins. I believe they are pretty much oem.
Old 02-18-2013, 12:08 PM
JrRifleCoach
JrRifleCoach's Avatar
Location: Freedom is never more than one generation away from extinction.
St. Jude '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16-'17-'18-‘19-'20-'21-'22-'23-'24
Its not rocket science.
The shocks go in and out like any other car.
Not to worry..
Old 02-18-2013, 02:27 PM
92ragtop
92ragtop's Avatar
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
On the rears, the shock stud attaches to a plate (#12 in the attached pic), which in turn attaches to the frame rail with two bolts.
Old 02-18-2013, 02:37 PM
Nocrsis
Nocrsis's Avatar
The reason I ask is because I was told for rear shocks. When car is jacked up and on stands with wheels off. the rear suspension should be set just like when car is sitting on ground with wheels on when you install rear shocks. Does that make sense?
Old 02-18-2013, 04:07 PM
RollaMo-LT4
RollaMo-LT4's Avatar
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10-'11-'12-'13-'14-'15-'16-'17-'19-'20-'21-'22-'23
See picture #3.
Place the car on jack stands, and then use a floor jack.
You just want to lift up a little to take the pressure off.
That way, the bolts will come right out easy.
Leave the floor jack in place until you get the new shock bolted on.
Then you can release the floor jack and move to the other side and do the same.
Old 02-18-2013, 05:26 PM
Nocrsis
Nocrsis's Avatar
Ok thanks so my buddy was exaggerating on the difficulty of changing rear shocks. I live in Michigan about 2 more months of winter. Snow SSUUCCKKSS
To Replace shocks on 94 c-4
Quick Reply: Replace shocks on 94 c-4
