Power antenna problem
Old 03-05-2013, 01:31 PM
PistolGrip
PistolGrip's Avatar
Default Power antenna problem
My '88 has a power antenna. I removed the mast & there is only about 4 inches of the geared nylon 'leader' left on it, so I'm guessing the rest is still wound up in the motor. What is the easiest/best/cheapest way to get the rest of the geared nylon out of the motor? I tried turning the radio on while someone else was holding the motor to see if any would come out, so I could grab onto it, but I couldn't see anything. The motor ran, but nothing showed up. It must still be in there, right? The motor still works fine, so I hate to buy a new one.
Old 03-05-2013, 02:18 PM
ccrazor
ccrazor's Avatar
St. Jude Donor '08-'09
This link gives a fairly complete set of instructions for the complete job but includes a bit about removing pieces broken inside..
http://www.antennamastsrus.com/GM/Ch...structions.htm
Old 03-05-2013, 04:08 PM
PistolGrip
PistolGrip's Avatar
ccrazor...Thanks! This will help me a lot.
To Power antenna problem
Quick Reply: Power antenna problem
