Fuel gauge is acting up!
Old 05-23-2013, 08:56 AM
MZee
MZee's Avatar
Default Fuel gauge is acting up!
My 1990 said 3/4 full, 1/2 full, then full all in the same block.
I put 20.00 in this morning, still fluctuates,same reading, what's up with that?
MZee
Old 05-23-2013, 07:25 PM
vetteoz
vetteoz's Avatar
http://forums.corvetteforum.com/c4-t...h-article.html
Old 05-23-2013, 08:54 PM
MZee
MZee's Avatar
Default wow
Thanks, that's really something.
I coughed when changing gears at 4000 rpm and now my car stalled out in a parking lot, restarts, idles but under pressure shutters and stalls again.
I will top up the fuel, let it sit for a couple of hours and then go get it hopefully, it's a mile from my house at an outdoor mall.
Maybe a fuel filter , who knows,
Thanks,
Zee
Old 05-24-2013, 12:36 AM
vetteoz
vetteoz's Avatar
Originally Posted by MZee
idles but under pressure shutters and stalls again.Maybe a fuel filter ,
Check the fuel pressure ;
your pump may be on the way out and not able to keep the pressure up when required
Old 05-24-2013, 01:24 AM
Cliff Harris
Cliff Harris's Avatar
The sock on my fuel pump rubbed against the bottom of the gas tank and shredded. The bits got sucked into the fuel pump. My car wouldn't go over 10 MPH and would stall immediately if I tried to give it too much gas.
MZee
MZee's Avatar
ok, thanks!
I put the basin , it ran home fine after a three hour rest,
MZee
Old 05-24-2013, 12:40 PM
MZee
MZee's Avatar
ok, thanks!
MZee
Thanks. I guess I will start with fuel filter
To Fuel gauge is acting up!
Quick Reply: Fuel gauge is acting up!
