will my digital dsah still work? using a fast system?
Does anyone know if I install a FAST system in my car will my digital dash and tach still work as well as the gauges? the car is a 91 and I have heard that all the dash runs thru the ccm? which is separate from the ecm? I just want to be sure my dash will work before I purchase the fast system
Thanks!!
Thanks!!
Im running the DFI Gen7. Everything works except the mpg calculator. All analogue gages are wired up.. speedo etc . Only thing I get is a sys flashng every few seconds which doesnt bother me at all. My factory ecu and wiring harness was completely removed from the engine compartment. I have a 93.
Sounds like it might be a nightmare to make that system work. Holley has a new throttle body injection system out as well that is all one package and self learning called the Terminator. I have electronic climate control on mine. I have no idea how the current computer system interacts with everything...then there's the digital dash as well.
yes that whats I was planning on doing.....just keep my stock ecm installed and then install the fast system plugging in only the connectors that are on the fast system and removing them from the ecm harness as I go. So leaving everything plugged in to the stock ecm except injectors, temp sensors, tps, map sensor etc. I'm just afraid of losing the digital dash...seems like if you dont have 5k to spend your screwed
thanks!!
