Saturday Fun
SWEET! I thought I saw it all, but obviously not; springs on the pushrods? WOW.... I would assume this is some form of valve train stability factor
It's the AFR hydra rev kit, pretty sweet.
http://www.airflowresearch.com/index.php?cPath=75
Learn something new every day......especially here!
... The head bolts are Fel Pro , OEM style , with ARP washers under them ... I used ARP bolts on the previous 400 with Cometic .030" MLS gaskets and wound up with cracks between the upper steam holes and the head bolt holes ... I decided to try "softer" grade 8 bolts and composite Fel Pro 1014 Permatorque head gaskets on this build in order to avoid ruining this block ... my thought process was to use bolts with increased elasticity and return to the much less expensive and far more forgiving composite head gaskets that had served me very well in the past ........... Good eye for detail BTW .....
Looking good. I really need to have one of those intakes made up for my truck one day. Love the look! Wish I had time to stop by tonight.
..... Not Yet ... this is an ongoing experiment that has just evolved to the rev kit phase ... I'm using light , small diameter valve springs that have been setup to stay within the pressure recommendations for a cast iron core camshaft ... no crazy spring pressures or rpm's ... my previous engine had a stock bottom end and I didn't want to find its true limit so I kept it under 7 grand ... once I work out the bugs on this edition I hope to get it on a chassis dynomomerator and see whats what ... this combo should produce power to 6500 at least ......
Now that intake has me intrigued, is that a tpi plenum attached to a single plane intake ? what manifold is that ?
... The base manifold is an Accel Pro-Ram , very similar to Edelbrock's Victor Jr but with a lower thermostat housing mounting pad ... gives more room for the throttle body and IAC ... welded a billet carb spacer to the bottom of a TPI plenum and welded the runner ports closed ... fits under the stock hood ... and all the factory brackets , hoses , and sensors can still be used in their stock locations ... seriously cuts down on the fabrication end .........
I had a look at summit, the Edelbrock E manifold is cheaper than the Accel, but the Accel seems to have fitting threads already in,
do you run the fuel pressure reg on the back ?
[QUOTE=C409;1584069414]..... The Edelbrock won't work with the OEM style throttle body without significant mods to the thermostat housing manifold ... its just too high ........ I use an Aeromotive remote FPR ... mounts to the top of the water pump ......... I did use a modified Edelbrock Torker II to see if it would bring back some low-end power ... it didn't change much ET or 60' wise ......../QUOTE]
that was my next question, does the single rail kill the low end torque ?
[QUOTE=blackozvet;1584077729]
... Oh definitely ... but it picks up large power in the upper RPM ranges , enough to offset the bottom end losses ... a high stall converter and numerically high rear axle ratios help to get things moving off the line ... this new setup of mine includes a Yank 4000 rpm stall and 3.91 gears ... when I switched from the FIRST intake to the Accel single plane , I lost a tenth off the 60 foot times but gained three tenths in 1/8th mile ET ... that was with a 2800 Vigilante and 3.45's ........
........ Made some smoke today ... finally ! ........ still waiting for the trans filter extension I ordered from B&M last week so I can utilize the extra fluid capacity provided by the 3 1/2 inch deep pan ... AND , so I can fill the trans with oil and drive this car ... started it without the converter bolted up ......... then , its on to the welder to get a six point roll cage installed ........... I should be racing by the end of July ............ DANG ! ........
[QUOTE=C409;1584078246]
thats pretty impressive, 3 tenths in the 1/8 over a FIRST, was that a FIRST long tube setup ?
are you going drag racing ?
your ahead of me, still hoping to fire mine up tomorrow, the pressure is on, I have entered for the next hillclimb on 23rd June and i still need to run it in !
